Lambretta Frame Numbers or VIN
6 απαντήσεις σε αυτό το θέμα
Καταχωρήθηκε 09 Νοέμβριος 2010 - 10:45 πμ
FRAME NUMBERS: MODEL A - MODEL F
Model A
1947: 5001 - 5153
1948: 5154 - 14,670
Model B
1948: 00,001 - 01,854
1949: 01,855 - 33,175
1950: 33,176 - 35,015
Model C
1950: 50,001 - 84,757
1951: 84,758 - 137,501
Model LC
1950: 400,001 - 416,813
1951: 416,814 - 442,501
Model D 125 (Mk 1)
1951: 00,001 - 03,865
1952: 03,866 - 68,451
1953: 68,452 - 69,000
Model D 125 (Mk 2)
1953: 69,001 - 91,506
1954: 91,507 - 122,642
Model D 125 (Mk 3)
1955: 122,643 - 122,992
1956: 122,993 - 123,142
LD 125 (Mk 1)
1951: 00,001 - 00,137
1952: 00,138 - 29,608
1953: 29,609 - 53,197
LD 125 (Mk 2 includes Elecstart version)
1953: 53,198 - 75,405
1954: 75,406 - 108,332
1955: 108,333 - 110,335
1956: 110,336 - 131,666
LD 125 (Mk 3 includes Elecstart version)
1957: 500,001 - 526,716
1958: 526,717 - 543,637
Model D 150 (Mk 2)
1954: 5,001 - 5,611
1955: 5,612 - 38, 759
Model D 150 (Mk 3)
1956: 38,760 - 59,593
LD 150 (Mk 2)
1954: 105,001 - 105,442
1955: 105,443 - 157,721
1956: 157,722 - 158,561
LD 150 (Mk 3)
1957: 200,001 - 281, 871
1958: 281,872 - 312,954
#2 YiannisGPX
Καταχωρήθηκε 09 Νοέμβριος 2010 - 10:47 πμ
FRAME NUMBERS: SERIES 1 LI 125 - TV 200
Li 125 (Series 1)
1958: 500,000 - 520,809
1959: 520,810 - 547,747
Li 150 (Series 1)
1958: 500,000 - 541,924
1959: 541,925 - 610,944
TV 175 (Series 1)
1957: 001,001 - 002126
1958: 002127 - 011088
Li 125 (Series 2)
1959: 700,00 - 709,838
1960: 709,839 - 769,059
1961: 769,060 - 811,087 (Note in 1961 some Li 125's had frame numbers starting with a 3)
Li 150 (Series 2)
1959: 800,000 - 825,725
1960: 825,726 - 921,714
1961: 921,715 - 100,602
TV 175 (Series 2)
1959: 100001 - 103261
1960: 103262 - 107464
1960: 200001 - 206005
1961: 206006 - 234323
Li 125 (Series 3)
1961: 001,001 - 003,125
1962: 003,126 - 051,477
1963: 051,478 - 101,942
1964: 101,943 - 127,289
1965: 127,290 - 143,241
1966: 143,242 - 145,263
1967: 145,264 - 146,735
Li 125 (Series 4)
1967 - 1968: 148,001 - 149, 400
Li 150 (Series 3)
1962: 600,001 - 648,718
1963: 648,719 - 696,739
1964: 696,740 - 714,018
1965: 714,019 - 731,133
1966: 731,134 - 742,064
1967: 742,065 - 743, 092
TV 175 (Series 3)
1962: 500001 - 513949
1963: 513950 - 531505
1964: 531506 - 545182
1965: 545183 - 552776
TV 200
1963: 520419 - 531505
#3 YiannisGPX
FRAME NUMBERS: LI 150 SPECIAL - GP 200
Li 150 Special
1963: 200,000 - 207,951
1964: 207,952 - 242,973
1965: 242,974 - 259,279
1966: 259,280 - 268,830
Li 125 Special
1965: 850,000 - 854,196
1966: 854,197 - 867,374
1967: 867,375 - 875,816
1968: 875,817 - 879,826
1969: 879,827 - 879,841
SX 150
1966: 750,001 - 753,571
1967: 753,572 - 767,228
1968: 767,229 - 781,072
1969: 781,073 - 781,239
SX 200
1966: 830,001 - 842,642
1967: 842,643 - 847,274
1968: 847,275 - 850-774
1969: 850,775 - 850,784
GP 125
1969: 001,001 - 009,450
1970: 009,451 - 015,892
1971: 015,893 - 017,302
GP 150
1969: 200,001 - 210,704
1970: 210,705 - 218,908
1971: 218,909 - 220,049
GP 200
1969: 250,001 - 254,778
1970: 254,779 - 258,602
1971: 258,603 - 259,351
#4 YiannisGPX
Καταχωρήθηκε 09 Νοέμβριος 2010 - 10:48 πμ
FRAME NUMBERS: CENTO - COMETA
Cento
1964: 800001 - 814085
1965: 814086 - 817643
J 50 (3 Speed)
1964: 400001 - 402799
1965: 402800 - 421383
1966: 421384 - 431022
J125 (3 Speed)
1964: 600001 - 606484
1965: 606485 - 616863
1966: 616864 - 621652
J50 (4 Speed)
To follow
J125 (4 Speed)
1966: 150001 - 158811
1967: 158812 - 161541
1968: 161542 - 166052
1969: 166053 - 166054
J50 De Luxe
1968: 500001 - 515098
1969: 515099 - 524143
1970: 524144 - 528,853
J 50 Special
1970: 500001 - 511447
1971: 511448 - 513600
Lui 50C & CL
1968: 575001 - 610763
1969: 610764 - 617910
Vega & Cometa
1968: 650001 - 654330
1969: 654331 - 654861
1970: 654862 - 659397
#5 YiannisGPX
Καταχωρήθηκε 09 Νοέμβριος 2010 - 10:49 πμ
ITALIAN FRAME NUMBER INFORMATION
Series 1:
Li 125: Frame - 125Li* followed by numbers starting from 500,001
Engine: 125Li* followed by numbers starting from 500,001
Li 150: Frame - 150Li* followed by numbers starting from 500,001
Engine: Li150 or 150Li* followed by numbers starting from 500,001
*Note: Information has been found that shoes that some of the engine numbers started with a 7. Also the frame prefixes have been found to be stamped either Li150 or 150Li
TV 175: Frame: 175TV* with numbers starting at 01,000
Engine: no info known at this time
Series 2:
Li 125: Frame: 125Li* followed by numbers starting from 700,001
Engine: 125Li* followed by numbers starting from 700,001
* NOTE: In 1961 a batch of Series 2 Li 125's were produced and have a frame number anomalie. These machines have frame numbers starting with a 3
Li 150: Frame: 150Li* followed by numbers starting from 800,001
Engine: 150Li* followed by numbers starting from 800,001
TV 175: Frame: 175TV2* with numbers starting from 100,001 (changing mid production to numbers starting 200,001)
Engine: 175TV/2* with numbers starting at 100,001 and changing to 200,001 mid production.
Series 3:
Li 125: Frame: Either 125Li or 125Li3* followed by numbers starting from 000,001
Engine: 125Li* followed by numbers starting from 000,001
Li 150: Frame: 150Li3* followed by numbers starting from 600,001
Engine: 150Li* followed by numbers starting from 600,001
*Note: The Li 150 engine numbers go up into the 700,001 range and can arise as the Li 150 Special engines also feature within that number range.
TV 175: Frame: 175TV3* followed by numbers starting from 500,001
Engine: 175TV/2* followed by numbers starting from 500,001
TV 200: Frame: TV3* followed by numbers starting at 512***
Engine: TV/2* followed by numbers starting at 512***
*Note: The TV 175's and TV 200's were built in batches and it is impossible to say exactly which number sequences were allocated to each machine.
Li 125 Special: Frame: 125LiS* followed by numbers starting from 850,001
Engine: 125LiS* followed by numbers starting at 850,001
Li 150 Special: Frame: 150LiS* followed by numbers starting at 200,001
Engine: 150Li* followed by numbers starting at 700,001
SX 150: Frame: SX150* followed by numbers starting at 750,001
Engine: SX150* followed by numbers starting at 750,001
SX 200: Frame: SX200* followed by numbers starting at 830,001
Engine: SX200* followed by numbers starting at 830,001
GP 125: Frame: 22/1* followed by numbers starting at 001,001
Engine: 125LiS* followed by numbers starting at 001,001
GP 150: Frame: 22/0* followed by numbers starting at 200,001
Engine: SX150* followed by numbers starting at 200,001
GP 200: Frame: 22/2* followed by numbers starting at 250,001
Engine: SX200* followed by numbers starting at 250,001
#6 YiannisGPX
Καταχωρήθηκε 09 Νοέμβριος 2010 - 10:55 πμ
SPANISH FRAME NUMBER INFORMATION
Series 2 Li 150: Built from 1960 - 1964 - frame numbers start at 000001 and run up to 045001+
Series 2 Li 125: Built from 1961 - 1964 - at present no frame number info is available
Series 2 TV 175: Built from 1963 - 1964 - at present no frame number info is available
Series 2 Li 150 (Winter): built from 1964 - 1965 - frame numbers start 040001
Series 2 Li 125 (Winter): built from 1964 - 1965 - at present no frame number info is available
Series 3 TV 175 (Winter): built from 1964 - 1965 - frame numbers start at 530001
Series 3 TV 175: built from 1964 - 1965 - at present no frame number info is available
Series 3 Li 125: built from 1965 - 1973 - frame numbers start at 200001
Li 150 Special: built from 1965 - 1973 - frame numbers start at 060001
Li 150 Special: built from 1966 - 1974 - frame numbers start at 300001
Li 150 Special: built from 1974 - 1979 - frame numbers start at 317401
Li 150 Special: built from 1979 - 1980 - frame numbers start at 325001
Jet 200: built from 1966 - 1971 - frame numbers start at 550001
Jet 200: built from 1971 - 1980 - frame starts at 550001
Series 80 200: built from 1980 - 1982 - no frame number information at present
Series 80 150: built from 1981 - 1983 - no frame number information at present
Series 80 125: built from 1981 - 1983 - no frame number information at present
Lynx 125: built in 1983 - no frame number information available
Lynx 150: built in 1983 - no frame number information available
Lynx 200: built in 1983 - no frame number information available
SX 125: built from 1984 - 1990 - frame numbers start 880001
SX 200E: built from 1984 - 1990 - no frame number information known at present
Πηγή: www.britishlambrettaarchive.co.uk
#7 YiannisGPX
Καταχωρήθηκε 01 Οκτώβριος 2011 - 17:47 μμ
Άλλο ένα χρήσιμο site
Lambretta Frame Number Guide
